Autor Tópico: Google vai lançar Google Chrome OS  (Lida 1453 vezes)
Offline trmanco
    • http://trmanco.com
« em: Julho 08, 2009, 12:58:43 pm »
Google Chrome OS is an open source, lightweight operating system that will initially be targeted at netbooks. Later this year we will open-source its code, and netbooks running Google Chrome OS will be available for consumers in the second half of 2010. Because we're already talking to partners about the project, and we'll soon be working with the open source community, we wanted to share our vision now so everyone understands what we are trying to achieve.
Speed, simplicity and security are the key aspects of Google Chrome OS. We're designing the OS to be fast and lightweight, to start up and get you onto the web in a few seconds. The user interface is minimal to stay out of your way, and most of the user experience takes place on the web. And as we did for the Google Chrome browser, we are going back to the basics and completely redesigning the underlying security architecture of the OS so that users don't have to deal with viruses, malware and security updates. It should just work.
Google Chrome OS will run on both x86 as well as ARM chips and we are working with multiple OEMs to bring a number of netbooks to market next year. The software architecture is simple — Google Chrome running within a new windowing system on top of a Linux kernel. For application developers, the web is the platform. All web-based applications will automatically work and new applications can be written using your favorite web technologies. And of course, these apps will run not only on Google Chrome OS, but on any standards-based browser on Windows, Mac and Linux thereby giving developers the largest user base of any platform.
Mais: http://googleblog.blogspot.com/2009/07/int...-chrome-os.html
Offline supremo
« Responder #1 em: Julho 08, 2009, 01:16:02 pm »
Google não para, quer ter tudo. Vamos ver como sai este SO.
Offline MuStAnG
    • http://GuitarClubPT.com
« Responder #2 em: Julho 08, 2009, 04:50:10 pm »
Se funcionar com cenas windows vai ser bom ... até estou curioso.. vai ser desta que deixo Windows xD
Offline trmanco
« Responder #3 em: Julho 08, 2009, 06:46:42 pm »
Citação de: MuStAnG
Aquilo vai usar Linux logo não vai ser possível ter aplicações do Windows a não ser que se use um programa específico para o caso.
E o objectivo de qualquer sistema é trabalhar com aplicações feitas para ele e não trabalhar com aplicações feitos para outros sistemas, essas coisas de "se funciona as aplicações do Windows e mais não sei o que, o Windows tem os dias contados", tem que acabar, há que parar com essas bocas, porque isto só mostra a plena ignorância das pessoas (sem ofensa) no que toca a sistemas operativos. Existem várias alternativas ao software proprietário é só uma questão de procurar.
O Google Chrome OS vai ser principalmente usado para netbooks que é onde Linux tem mais possibilidade de entrar e conquistar esse mercado já que o os processadores ARM são o futuro nestes aparelhos e o Windows não corre em ARM.
Não leves a mal o que disse, mas a verdade é essa
